Removing driver's seat
Parrot of Doom
Manchester
Is it a big deal to remove the seat on a 1997 W210? Just bog-standard, nothing fancy on it.
I want to clean the cover and also underneath (as well as regreasing the rails), but also my seat has developed an annoying creak on acceleration that seems to be a common problem requiring a couple of washers in the base.
Ellsy Tanners
Mars
No this is very easy, four torx fixing bolts, and a bolt which holds the seat belt to the base. Then a few electrical connectors underneath
