Removing indicator bulb housing
jon pollard
I can't believe I'm having problems changing an indicator bulb!!
I have a C200K 01 Model, and I'm trying to change the front nearside indicator bulb. I can turn the bulb housing anti-clockwise, but it won't extract once turned. Offside indicator removes fine and upon turning seems to click into position to enable removal - The nearside one doesn't even do this, it just turns about 45 degrees and then refuses to be pulled out, even with large force applied!!
Any suggestions?
LANDR0VER
Banned
In a land far far away
Any suggestions?
Remove the complete unit and try it then,this way you will be able to see what is going on...
