My W210(it's an E320CDI) has failing pixels (clock and gear selected)and I need the cluster out to send off for repair.
There are NO slots into which I can slide tools. I have read that if I remove the driver's air vent( not a problem) that I can then reach in and simply push the whole assembly out from the back? Is this so or do I then break a load of plastic clips carefully hidden to further line the local franchise':roll:s pockets?
If it is not the right way, does anyone know what is?
Thanks in anticipation
