bloodworm
- Jan 26, 2021
- Eclass 2015 220D
hi again, do any of you use a syphon to remove the engine oil?. The reason I ask is that I`ve owned the motor for 3 years and had it serviced at an approved garage, they`ve done the last 3 services A, B, A and it will soon be due the B service, in the past it has had the following in addition to service items, rear diff oil changed (at my request), new fuel filter, new pollen and engine air filters, brake fluid change, a/c re :-gassed, new water pump, new oxygen sensor and brakes all round 3k ago. So seeing as it is due the full service and really all that needs changing is the oil and filter I will do it myself as I am keeping the car so no future service record is required. It seems easier to syphon out the oil than putting it on ramps or stands plus I`m not getting any younger. cheers.
