I had to remove both front seats from my CLK320 Cabriolet in order to remove the carpets as there was water getting in and the footwells were soaked anyway, I just removed the bolts holding the frames down, tilted the seats back a bit so that I could gain access to the wiring etc., unplugged the connectors, then removed the seats. Fitting was just the reverse of this procedure. The connector plugs can only fit one way. so there's no chance of mixing them up etc., hope this helpsany ideaon the wiring diagrams for the seats non memory and not heated cheers
Thank you Malcolm. I will see if Bigaston can help.
Is this for a 208 please
