Chrishazle
- May 25, 2009
- Location
- Nr Ashford, Kent
- S204 2008 C220CDI Elegance Estate Auto, 2008 R171 Facelift SLK280
Attempting to fit a replacement blade to this beastie I managed to break the little plastic clips that holds the blade to the arm, so sourced a replacement arm and a Neilsen CT1785 battery terminal/wiper arm puller, gave the drive shaft a little penetrating oil while waiting for everything to arrive.
This morning I've removed the locking nut from the shaft - fairly easily - and been trying to remove the arm. Given it lots of good quality penetrating oil, got the puller properly mounted, about every half hour for 2 1/2 hours now I've tried tightening the puller as much as I can, loosened it off, squirted more penetrating fluid and left it to soak. Still no movement of the arm coming free on the shaft!
Other than continued 30 minute soak and wait, the only other thing I wonder about trying is, with the puller on and tight, switch the rear wiper on for 1 wipe - but not sure if that might overload the motor.
Any other tips for getting this beastie off? TIA guys and dolls!!
Chris
Chris
