robmc52
- Jul 6, 2009
- Location
- The glorious Kingdom of Thanet
- W220 2005 S320 CDI Previously...W210 2002 220cdi, W202 2000 C200T Kompressor
Morning all, having recently done some work on the airmatic pump and valve block on my W220, I'm getting an intermittent warning on the dash, when starting from cold, I can hear the pump run for a couple of seconds then it cuts out and the 'Airmatic visit workshop' warning appears.
If I turn it off and wait for the dash lights to go out and start it again it then runs fine for the rest of the day.
I have renewed the relay, and also cleaned as many of the electrical connectors that I can get to, including all the ones on the pump and valve block.
I did notice whilst working on it, that the cabling to the valve block looks like it's been twiddled with at some point in the past, and upon further inspection that there's a couple of crimped connectors on the cables that go to the pressure sensor.
I'm thinking now about stripping the wrap off and taking a closer look, but I'm unsure if I'd be able to check the continuity of the cables, as I have no idea where they terminate at the other end.
Also, is it possible to buy the actual pins that go in the connecting blocks? in case I need to change a cable that's close to one of the existing pins.
