Repair STAR SD C4 Multiplexor connection
Conor
London, UK
Hey all
I'm having a connectivity problem with my STAR system right now.
Nothing else changed on the system so I suspect it's a loose wire somewhere. When I went at it yesterday I noticed one of the connectors had come loose and I could see the individual wires exposed. The connections are soldered so one could have easily broken.
Does anybody know how to open up this connector so I can access the PIN breakout board and inspect each connection?
Also, while i'm here. Has anybody put STAR onto a modern computer and used a USB -> RS232 (Serial) adapter? The old Dell laptop I have for it is old and I expect the HDD to give up any day now.
Many thanks
Conor
Looks like you can hold the red arrowed bit and unscrew the yellow arrowed bit from the picture - just be careful when unscrewing that the cables don't turn or you'll have them all snapped off...
Conor
Conor
London, UK
Thanks BC but my apologies - it's a bad photo.
The black pieces you have marked out are separate to the metal piece .. which is the problem. All the individual wires are exposed now.
I need to extract the board with the pins/solder connections so I can resolder (2 are broken).
Arrgh.
It is a fiddly job (I used to make off mulitcore Nato Connectors)
Conor
Conor
London, UK
It seems fiddly but is a necessity now :(
Do you know if you can extract the board with the solder pins? I wonder where I would get the pinout diagram?
Snake Charmer
S211 E320 CDI 2004
The black plastic parts look like a cable gland, loosening that will give you a bit more room.
Conor
Conor
London, UK
Errr.... do I need to just de-pin each pin out the back, re-solder and then re-pin?
If you can get the rest of it to slide out you could just solder onto the back and put some heat shrink around it. Getting the pins put and back again can take effort as there's usually a barb that prevents them sliding out - getting that barb out of the way without damaging the pin or the surround is challenging.
Conor
Conor
London, UK
Ok.. so my colleagues over on the Mig Welding forum advised me of the solution... you need to insert the connector back into the opposing connector and the mane body of this connector unscrews. Like magic.
Oh and I found pinout online too. http://stardiag.net/star-diagnosis-c3-main-cable-rs-232-485-pinout-diagram/
Given time i'll maybe post a tutorial on a fix.. but if I don't get around to it, i'll try and keep this page updated and future readers can reply with questions if needed.
