Replace Cam Adjuster Magnet : NEED HELP
royaltramp
I need to change my Cam Adjuster Magnet and install starter line to stop oil leak on my C200 Kompressor 2001 . Need full procedure/steps on how to do it.Preparably with photos. Thanks is advance
You just buy the blocker,, pull the wire connector of the sensor,,plug in the blocker and put the wire that you took off into the blocker.
Welcome to the forum
Cole@MBS
www.mbssouthampton.co.uk
Its as simple as Malc said! you can change the sensor but the blocker will do the job!
