"Replace Key Battery" warning - R230
wrightkarl
Malvern
210 E320, E430 - 211 320CDi & CDi Sport - E350CDi Sport - 215 CL500 - R129 SL500 - R230 SL500
Hi all
Curious if anyone knows what must be a simple answer to this... I hope
Despite my keys having new Duracell batteries, the cars display tells me to change my batteries ? Still opens and starts keyless as it should, just the warning.
Any suggestions ??
Karl
mioba
Nottingham and Köln
Maybe a code reader is needed to clear the fault message.
wrightkarl
wrightkarl
Malvern
You'd like to think this would be a self clearing fault, even if its really a fault, I'll bear it mind though
mioba
Nottingham and Köln
some faults need the code cleared once the offending part
has been fixed. .
Viscount
Scotland
SL / 2003 / 3.7L
I know this is an old post but I have this issue but only with 1 of my 2 keys suggesting the issue is with the key rather than the car. Anyone got any ideas/experiences?
brandwooddixon
Wolverhampton
S63 Coupe 2014
Some keys have a long coil on the PCB that becomes detached when the keys are dropped onto a hard surface. The infrared transmitter still works, but the radio frequencies don't. Diligent application of solder and iron can sort it.
bc100
South Devon
S205 C250 BluTec Estate 2014
I once had a problem with Duracell batteries in a lighting system remote. Their support said the child safety flavour coating had caused problems in some of their remotes but not others. Sure enough, a cheap supermarket battery worked straight away. Never had that problem with my car keys however.
Submariner1
Windsor Berkshire
CL500 2009 5.5
Had a problem on my SL500, If I remember, correctly something like “key not recognised” so handle would not open door - with new duracells.
Changed to genuine Merc batteries worked perfectly !
Bizzarre to me as a battery is a battery?
Viscount
Scotland
SL / 2003 / 3.7L
The key is working fine. The only issue is that the car believes the battery in the key needs replaced. I've ordered Duracell batteries and will try one when received. I will also clean the contacts in case there's high resistance. Thanks for the feedback.
Viscount
Scotland
SL / 2003 / 3.7L
Duracell made no difference so went back to the Panasonic battery. I cleaned the contacts (including the mating contacts on the battery holder and key itself) with switch cleaner and a cotton bud. Sorted!
