Replacement alarm siren
Taffy7hfa
Oxford
New part came today from MB Grangemouth, thanks chaps the old one was a bit of a mess , no wonder the car was going crazy D61CD842-BBC6-4DB1-8954-3100FB2857CD.jpeg
mioba
Nottingham and Köln
Good stuff on tackling that. ....and all fitted and behaving.
Taffy7hfa
Taffy7hfa
Oxford
Not yet, will have to wait until the weekend now, I'm pretty confident it will fix the problem though.
mioba
Nottingham and Köln
no doubt looking at the original....
keep us posted and good luck
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
MB should be able seal that alarm watertight, this is not the first one on the forum.
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
You should notice a beep on locking the car after fitting the new alarm.
mattkh
England
A160 W168 1999 1.6
Please, look at the old and new alarms to find out who manufactures this alarm. Any info will be appreciated.
mioba
Nottingham and Köln
I would be consideruing at getting some sika around the joints on that. but then again the cost of sika is not cheap fot the amount you would use.
It may be they are not super sealed as they need to let heat out.
Considering they last a good amount of time, I probably would just replace makiing sure any potential openings in the device are facing down/away from areas of potential dirt/moisture ingress.
Taffy7hfa
Taffy7hfa
Oxford
Its a good shout although I'm not sure if it is a moisture related problem, my understanding is that the batteries inside the unit start to break down over time its the acid that then kills the PCB. I know its a really common problem on lots of 15-20 year old Mercs. The unit is not in an especially vulnerable location on the ML either its tucked away under the scuttle below the wiper assembly.
