Replacement bulb
blueclk
The bulb behind the air flow direction dial on my W208 CLK200K has gone what is the easiest way to replace this?
The bulb for the fan dial still works ok.
thanks
Ellsy Tanners
Mars
The knob pulls or prys off then you will see a tiny peanut illumination bulb behind a white plastic tap. I very small pair of electrical long nose pillers will be reqiured to pull out the bulb.
BlackC55
South coast
C43
You can also use a small length of vacuum pipe to pull it off and push it on.
