Replacement Engine or Rebuild Head?
Status
Not open for further replies.
Orlando 300E
Edinburgh
Hello,
I need advice with my 91? 300E, 124 chassis fitted with an M103 engine.
The car has covered 250k miles, 230K with its only :D former owner, with the last 20k over the past 12 months. Unfortunately when I purchased the car it had not been used regularly or maintained :( very well for 2 years (but I got it for a great price :) ).
I found after a month of driving that the entire coolant system was ?goosed?, the biggest problem was when the top hose popped of the cracked plastic :shock: thermostat housing, drenching my entire engine bay in sticky coolant and baking the engine, all in less than two minutes.
After that excitement I proceeded to replace the entire coolant system ?including the thermostat housing, I was pleased to see they now come from MB in metal :D .
After much blood letting, swearing and even genuine Mercedes coolant all was well on my automotive world......or so I thought.
Two months latter during the summer, with the heat (even here in Scotland), road repairs and the inevitable traffic cues I found that my coolant was dropping. Not at an alarming rate (1 litre in 400 miles). There were no obvious signs of a leak or any drop in the usual good performance. Even the fuel consumption was unchanged. Not even engine roughness as a clue to a blown head gasket.
It wasn?t till two months passed, when the car was up on a ramp in a garage did I find the leak. It was coming from the head gasket joint hidden behind the exhaust manifold, adjacent to No.5 cylinder. My blood ran cold at the thought of more expense- forgot to mention the garage was a auto box specialist, but that?s another story!
Monitoring the leak has shown that the coolant only escapes in traffic, when the dash temp. gauge starts to rise. Otherwise there had been is no loss performance, increase in fuel guzzling or change in smoothness.
That is until now after 6 months of nursing, I have started to notice a drop in performance and fuel consumption has increased. The former could be just paranoia and the later because I have not had any good long runs only been stuck in the city.
What out of the following should I do?
1. Bearing in mind the mileage the engine has done, should I go for a new head gasket with inevitable head rebuild + find out that the bottom end is not in good shape either and also spend quite a while without my beloved Merc.
2. Find a new (to me) used engine, that won?t take so long being separated from her outdoors. If this is the best option, could any of you suggest a good second hand engine supplier, possibly with guarantee? Please don?t suggest ?The Garage? :twisted: or ?Dronsfields? :evil: already had bad dealings with both.
3. Any other suggestions?
Over to you guys, Please help!
O
Orlando 300E
Edinburgh
Thankyou Dave,
I will contact that company to see how mutch they will charge.
But I dont think I will be able to aford a reconditioned engine.
cheers
Orlando
dieselman
A diesel
Have a compression check on all cylinders.
If that checks out ok on all but the suspect cylinders, and assuming the engine doesn't have any untoward rattles then I would go for a head job.
You should check the flatness of the head whilst it is off and if you are feeling flush have new piston rings installed.
Whilst the head is off you could check the condition of the bores, but if the car hasn't been burning oil all is probably ok.
Andy
West Midlands
www.mercedesservicing.com
Hi all
Have you forgotten what I have said about compression tests. Cylinder leakage test is the way forward. But at 250k the bottom end will probably be ok. Or still serviciable. If I were you I would go for a new head gasket. If the cylinder leakage test does not show any untoward troubles then remove the camshaft and skim the cylinder head. It will need doing as it will have marked the cyl head where the water has escaped. I would also check for marks in the cylinder head around the water galleries where it may be eaten away.
Good luck
Andy @ www.mercedesservicing.com
Tony Browne
Ireland
Hi all, ..... yep! remove the head and get it skimed, fit new head gasket and thermostat.. and coolant...check hoses and rad for blockages.
then leave it alone !!!! but do skim the head even if it looks good......
O
Orlando 300E
Edinburgh
Next Step!
Hello again,
thank you all for your advice :)
Decided to do a few checks today (Sat) in daylight.
I purchased a compression tester & ran the test, the results from front (1) to back (6) in Bar are:
11.4 11.2 11.7 11.0 11.2 11.7.
I have to admit I miss read the instructions- I only removed one plug at a time rather than all, hope this dose not affect the result.
Returning indoors to consult the Haynes manual. for my engine the minimum acceptable compression pressure is 8.5 Bars (approx) with a max difference between the cylinders of 1.5 Bars.
It seems that my head gaskit is healthy, with only a single water-way leaking at higher temperatures.
on the subject of higher temperatures, it seems my fans viscous coupling has locked, found this out by doing the "carrot" test, that fan works a treat as gratter! :wink: This could explain the increase in fuel consumption.
Dont think I will do anything to it untill I get round to doing the head gaskit- its keeping every thing cool (except the bank balance!).
Thank you all agian
Orlando
Status
