The engine was idling unevenly and running 'rough'. Part way to getting it looked at by a mechanic, the engine started spluttering and stalling. This was intermittent to start with, became more frequent until the car wouldn't start and had to be towed to the garage. The mechanic was able to fire it up a few times the following day and diagnosed a faulty fuel metering head and said that too much fuel appeared to be getting into the engine.What are the symptoms at the moment..??
Sorry to hear about your brother..... said that too much fuel appeared to be getting into the engine.
Thanks - I've asked the mechanic to look out for these issues.Sorry to hear about your brother.
Overfuelling can be a leaking/stuck injector.
The saucer in the metering head has to have very clean circumference in order to move up and down freely.
Also consider the condition of the fuel in the tank.
The mechanic says that the saucer in the current is moving *too* freely and sinking back into the chamber with virtually no resistance. Presumably, this movement somehow controls the fuel supplied by the other side of the unit (excuse me if this is incorrect - I'm not a mechanic!). Anyway, we'll fit the new part on the weekend and see how the old girl responds. Thanks again for your response.Sorry to hear about your brother.
It would still be useful to know if anyone can repair these things just in case the ebay part doesn't work.
Its the fuel pressure regulator for the metering head. It's bolted to to the engine block and controls the fuel pressure according to engine temperature.Please refresh my memory about what you call the warm up regulator.
Yes, its a Bosch part - "MERCEDES W123 FUEL METERING HEAD C 0438120116". I have managed to find a used & working part on ebay now and the mechanic will hopefully be able to fit it in the next couple of weeks. It would still be useful to know if anyone can repair these things just in case the ebay part doesn't work.
