survey
- Feb 10, 2009
- Location
- Suffolk
- 2012 C207 E250cdi Sport Coupe
My E Coupe apparently needs new tyres. Covered 23000miles on its Continental Contact 5's. Apparently I have a very small hole in each of the rear tyres that goes to the cord (caused by the stones on my drive no doubt); the tread depth is 2.8-4mm across the centre 3/4 of the tyres. The fronts are worn to 3.4-5mm across the centre 3/4 of the tyres although the edges are like most of my MB's are wearing worse.
I am off to Europe at the end of the month and will do appox. 2500miles. I had hoped to keep these tyres on and replace at least the rears on my return. But wth the news of the holes in the rear tyres, I wonder if I should replace the rears before I go, or indeed fronts as well. Any thoughts?
Tyre choice. I am quite pleased with the Continentals and looking at the wear they would have gone for quite a few thousand miles more. Before I speak to my usual local tyre dealer, the cheapest I have found is £165 rears and £150 fronts. If I chose say Kumho KU39's then the costs are £139 and £128 respectively. Now are the Conti's worth the extra from a wear and noise point of view? I have had Kumho's and Michelin Primacy on other MB's and found them fine. Michelins I like but the cost is more than the Contis!
