Replacing Crankshaft Pulley on 99 ML320
Mikesmerc
Co.Cork IRL
2001 CL500,1990 560SEC, 1988 230E, 1982 250, 1979 280CE, 1977 200D, 1972 350 SL, 1965 220S Fintail
Hello all, picking up my new pulley later today and hope to fit it tonight. What do I have to strip to fit it?. I know there is a large bolt holding it, do I need pullers?
Thanks in advance
Mike
It may come off without
Tell you what, give me your Email address and I will send you the instruction and torque settings
M
Mikesmerc
Co.Cork IRL
Cheers Malcolm, sent you a PM.
Rgds
Mike
I have sent it and hope that it goes well and best regards
M
Mikesmerc
Co.Cork IRL
Right, havin a go tonight, one or two stupid questions, does the crankshaft rotate clockwise as you look from the front and if so does the pulley bolt unscrew clockwise to prevent it loosening during normal running?
Sorry
Mike
The engine does rotate clock wise,,if the bolt had been LHT it would have said,,so good luck
colechelle
Resigned
you know you need a workshop tool to hold/lock the pully as you undo it!!! and replace!!!
colechelle
Resigned
Yes Black, f,,,,,, tight, seen a snap on bar SNAP doing one of those!!!!!
colechelle
Resigned
Nice one malcolm, he will need that, they are a pig without, infact i would be surpised if it was poss to do without it??
When I fitted my new steering wheel last week no bar would shift it,, the air tool in the garage undid it after 30 sec,,the electric one did nothing.
I have seen crank shaft U/S when they have not been torqued up correctly and the key way groove goes,, and thats the end of the crankshaft
colechelle
Resigned
yes i know what you mean malcolm thats why we have to do anything up to the correct torgue, seen so many horror storys where bolts have been snapped, left finger tight !!!!!
M
Mikesmerc
Co.Cork IRL
Cheers guys, yes Malcolm thankfully sent me the procedure, just had to make sure of the thread, the only thing worse than trying to loosen something is to end up tightening it even more like offside wheel nuts on a truck( you need not ask how I found that out). Have done the timing belt on my old Land Rover 90 which involved removing the pulley, wee trick was to stick a socket on the nut with a hefty power bar attached, rotate the bar until it made contact with the underside of the chassis, disconnect the power to the shut-off solenoid at the injection pump, give the key a turn and bobs your uncle.
Yes things a bit more complicated here which doesnt lend itself to this procedure.
Mike
M
Mikesmerc
Co.Cork IRL
Job done, couldnt even shift the bolt with an air gun, long power bar and this thingy(desperate times calls for desperate measures,see pic) and may come in usefull for frightening double glazing sales men away.
Cheers
Mike
colechelle
Resigned
well at lease you got it done, everytime i do one i use a 3/4 inch drive power bar and 6 foot tube, even then its still a job and half, nice diy tool!
M
Mikesmerc
Co.Cork IRL
  • #19
Cheers, bet it will last longer than a harmonic balancer too.:rolleyes:
Mike
Good news Mike so pleased its all done,,good one:D:D
