Hi there and welcome. Its no problem all you do is remove door card . On the pull open handle you take off the cover , this will give you access to a 10 mm bolt .take it out.
if it has wind up windows remove handle .
the door card will now lift up and out .
it is quite difficult to explain on a computer why dont you buy a haynes manual all is explained in detail with pictures
hope this helps Regards Land-Rover.......................
GAD was founded in 2009 where we developed bespoke ECU Remapping software for motorsport clients, moving forward, we have extended to road vehicles for both performance and economy, contact GAD Tuninghttp://www.GADTuning.co.ukto discuss your requirements.
