Malcolm Brown
- Dec 12, 2001
- Location
- Macclesfield, Cheshire
- Website
- www.******************.co.uk
The external temp dial on my 1988 SL constantly reads max temperature. I have assumed the sensor is a simple thermistor which is faulty (shorting) and have got hold of a new one (the MB part number is not 107-specific). It has a long cable (2 wires) attached with a plastic connector on the other end. This connector is different from the one at the back of the meter, which has 4 wires. The new sensor also came with a small packet containing 3 pairs of small aluminium pin-type devices in different sizes and a small rectangular plastic thing that looks like a connector of some sort - no idea what those are for.
There must clearly be a connection in the cable - to introduce power via the two extra wires - but I can't find it. The cable from the sensor, which is behind the front number plate, runs into a bundle of wires and I've not managed to trace it right through. Please does anyone know whereabouts the connector is?
If I can't find it, or if it is somewhere difficult to access, can anyone think of a reason why I should not just cut and join the existing cable to the new? Provided I make a very good connection and don't change the length of the wires, then it shouldn't affect the calibration significantly. There's about 3 metres of wire so I reckon that if I match the cable length as closely as I can, the change in the total resistance of the wire should be very, very small - certainly less than 1%. Of course, this is only a theory - and it fails completely if the problem isn't a faulty sensor!
PS. One day, I hope I'll be able to answer a question - I'm just asking them at the moment. But there's lots of fascinating reading and some very helpful people in these forums.
