replacing flat bonnet badge with an upright one?
P
PanzerMcGrory
I have an ml and i miss looking down the bonnet at a three pointed star like i had on my old e class. does anyone know if there is an upright badge made that can replace the flat bonnet badge found on MLs and other flat badges mercs.
Thanks Don.
WRAGGY
Matlock ENGLAND
C180 SPORTS COUPE
whitenemesis
CLS55 AMG '05
Buy the star and mounting and then measure?
C
C180 Chris
The bonnet star sits in a recess, do you have that for your badge or is it flush mounted?
roadhog
Sunny Norfolk
W124 300D x2, C124 300
What have I missed? Why is panzer listed as a guest? :confused:
Apologies in advance if this is a sensitive subject and all that......
100%Bitch
Norfolk 'n' good
He probably hasn't signed in.
dizzy lizzy
sunny devon
SL129 (diesel),2 x 124 250D,190d 2.5
i thought you couldn't post if you were signed in as a guest- or am i wrong?
SilverSaloon
w124/1994/om606
i assume ML has the flat badge assuming its like other mercs - take that off and you should see (if like other mercs) that this is held on by a bolt & hole. as previously mentioned, it needs to sit in a recess.
if not, then try something like this:
SilverSaloon
w124/1994/om606
if not, then try something like this, but fit the star on the mount instead of the flat badge:
