guruzeus
- Jul 4, 2024
- Vito w639 2007 2.1
Hello
Vito w639 2007 has an automatic gearbox issue - transmission is in a limp mode (not shifting gears above the first). The dealer has quoted replacement of the shifter and gearbox control module with a heavy price tag. I have replaced the shifter without success, so I need some advice to move forward.
Do I need to do anything after replacing the shifter? (eg delete codes or reset module)
Is it possible to fit the module as a used part and does the module have to have exactly the same codes and readings on it as the old one? (basically, what is the essential when searching for a plug and play replacement)
When replacing the gearbox control module, do I have to nessecarily reprogram it to fit it to the car?
Zeus
Zeus
