Replacing indicator LED cluster in door mirrors. CLS 2005
MercedesMax
Brighton
CLS 2005 320CDi
The LED cluster in my CLS 320CDi 2005 has stopped working on the drivers side.
My CLS has the power folding mirrors.
Can someone tell me how to replace this?
:confused:
Do I need to spring the glass out to access the LED module or can I remove the cover without removing the glass.
Thanks !!
I can send you the instructions :D this is normally a broken wire if you fold them a lot
M
MercedesMax
Brighton
CLS 2005 320CDi
Great !!
That would be great - Thanks !!!
They fold everytime I lock the car so only a few thousand times to date :D
Sorry if this is a bit dense but
how do I give you my email without posting it ?
Just pop it up here and you can edit it out in a few minutes
M
MercedesMax
Brighton
CLS 2005 320CDi
OK
OK and 1 sent, you can remove your address in edit while I print off the glass paper.
It will be a broken wire
M
MercedesMax
Brighton
CLS 2005 320CDi
Mirror glass removal
Thank you very much !!
To get the glass out is it tilt the miror fully down and then press on the bottom of the glass while pulling the top so the spring legs disconnect from the motor mount ?
OK I have printed it off and sent it
M
MercedesMax
Brighton
CLS 2005 320CDi
Thats impressive !!
Thanks very much indeed.
Best Regards and
Happy New Year !
Thank you :D We are the only forum in the world where work sheets get sent out:D:D
