charlysays
- Jan 11, 2016
- Location
- Pembrokeshire
- Mercedes C250 Turbodiesel Sport Auto Estate
Just finished a refurb of the rear subframe and underbody in that area, fuel tanks off etc.
The issue I'm having is that when I bolt up the front mounts for the rear subframe, there's a gap of several mm between the rubber backed washer and the subframe.
See pics.
The bushes are from Merc main dealer and have the same part number as the original ones I removed (starts 124).
Is there meant to be this gap between the washer and the subframe?
Very confusing as it's not as though there are options for other variations of the bush and there aren't any parts missing... You have the bush, the subframe, the rubber backed washer and the bolt but it looks like it wants a shim!. The subframe was rusty before I blasted it and painted with epoxy mastic but it's hardly likely that 3-4mm has gone missing from the top face for the inner part of the bush to stick out this far underneath.
Any ideas or is it meant to float like this?
Pics taken off the car but with the subframe on the car its the same, when you tighten the bolt it doesn't pull together and there's this gap between the washer and the subframe.
Now if the springs were fitted, the bush would undoubtedly slide In the subframe so that it was pressing on the washer instead but then there would be a gap on the top side.
It's as though the bush inner is too long or the subframe isn't thick enough for the bush? In the bottom pic you can clearly see the bush inner protruding beyond the subframe by several mm.
See pics.
