VenomX
- Jun 14, 2024
- W203 C240 2002
Looking to change my coils and shocks at the front because the front passenger has what I believe to be a very worn shock absorber ( really rough if one side hits a bump ) someone on YouTube with a similar Mercedes fixed it by replacing the shock.
I have looked up the VIN code list, and nothing is mentioned regarding sports or increased ground clearance - so I think that the suspension is standard and not " sport "
The current coils have two yellow blobs on them ( two on each coil ) which apparently matches this OE number "A2033214104" - according to a Mercedes parts site.
Looking at my usual supplier, they stock " standard " or " sport " suspension.
Will my car drive OK if I buy standard shocks ( most likely Napa/Apec or NK ) and standard coils ( KYB ) ?
Car is a 2002 C240 Saloon Avantgarde. Here are the codes..
I know there is a points system, which is even more confusing, but I understand this is because certain options will affect the weight of the car and therefore coils have to be fitted accordingly.
All I want is mid-range comfortable soft suspension at the front to replace the worn shocks. May as well get the coils whilst I'm at it, aftermarket is fine.
