mcnevermind
- Mar 1, 2005
When the reserve fuel light comes on in a 1.8 190e how longs left in the tank? a few miles or plenty
mcnevermind said:When the reserve fuel light comes on in a 1.8 190e how longs left in the tank? a few miles or plenty
philharve said:Can someone please confirm whether the connection between the fuel tank and the fuel gauge is a simple 1 or 2 wirelink and there isn't a processor intercepting the fuel level signal and outputting a signal to drive the fuel gauge needle, the yellow LED and any other associated instrumentation?
The reason for my inquiry is that I've noticed that once the fuel warning LED comes on, it doesn't flash as the fuel sloshes around in the tank. Once on, it stays on. However, if the car is switched off and then on again, the needle can appear higher up the gauge and the yellow LED may be off. I wouldn't expect this behaviour if a simple 1 or 2 wire connection was involved. The readings would be consistent.
REGARDS Phil
