Reservoir cap
Graeme 1978
South Shields
E220 2012 2.1
Hi all should these caps have a hole in them to vent them or not.
Cheers
Sent from my SM-A145R using Tapatalk
G
Graeme 1978
South Shields
E220 2012 2.1
Sorry brake reservoir.
Silly me
G
Graeme 1978
South Shields
E220 2012 2.1
A have checked mine and there's no hole in the cap and so a had a look at some on Web sites and those don't appear to have holes in either that's why am wondering should it have a hole in the cap.
Are Mercedes ones made differently were as they don't need holes in.
Thanks graeme
EmilysDad
Bury Lancs
ML350
There needs to be a vent in the cap somewhere because the fluid drops very slowly falling due to pad wear. If it didn't vent, it'd try and draw a slight vacuum in the reservoir.
G
Graeme 1978
South Shields
E220 2012 2.1
So would you say a need to drill a small hole in the cap or NOT
G
Graeme 1978
South Shields
E220 2012 2.1
Am only trying to workout if there's something wrong.
When the cap is tight securely tight the brakes are let's just say they are OK.
So a undone the cap just to brake the air tight seal so the cap is not off but just undone.
Since a done that my god the brake peddle has come up and by god they work just touch the peddle and am nearly head butting the windscreen to me that's the way the brakes should be.
So if the cap is undone slightly and the brakes work amazingly is that right or wrong.
If a tighten the cap down properly and the brake peddle has travel on it and not as good is that right or wrong.
So should the cap have a small hole in it or not that's the moral of the story.
Thanks graeme
Doug1234
Bedfordshire uk
1997 w210 e300td
Take the cap off and look and see if it has cling film under it.
Sometimes when brake parts like callipers and hoses are being changed people put cling film under the cap to stop air getting in as this slows the escape of fluid.
G
Graeme 1978
South Shields
E220 2012 2.1
Defo no cling film there cheers
Doug1234
Bedfordshire uk
1997 w210 e300td
It does seem odd and I’m quite sure the caps do maybe have a diaphragm of some kind but my years of driving have me thinking master cylinder seals because of the pedal staying down
G
Graeme 1978
South Shields
E220 2012 2.1
The pedals not staying down the brakes are working it just they work better when the cap is loose not tight.
Am just wondering if other people have had similar issues.
But thanks for your input.
Or should there be a breather hole in the brake reservoir cap
Doug1234
Bedfordshire uk
1997 w210 e300td
They let air in but not out as far as I’m aware , so as pads wear down they let air in to compensate for fluid level dropping down.
