reset ecu??
Merc_786
Is it possible to reset the ecu or the instument cluster itself on the e320 cdi 2002 model as mines showing a malfunction but after a diagnostic test its showing no faults.
any help will be much appreciated, Thanks in advance
Xtractorfan
S class
What is the mafunction it is showing
M
Merc_786
Its showing (steering gear oil visit workshop) checked oil its fine also put it on diagnostic and it shod no faults.
M
Merc_786
by the way i got told by the previous owner that the instrument cluster got replaced by a second hand one so just thinking if the problem could be of that.
Xtractorfan
S class
yes its quite possible that the fault is logged in the cluster..have u checked with your local dealer a lot of these cars had software updates to eradicate erronious faults..other thing that could cause it is a faulty sensor in the power steering system.. a change of power steering fluid may solve your problem ..the old stuff could be manky
M
Merc_786
Thanks ill check with the dealer 2mmrw, also il change the power steering oil just incase thats the problem. Just curious if i disconnected the battery for a while will that not reset it back to factory setings??
