Restraint System visit workshop SRS
The Rillo Boy
Hiya Guys, got a message saying RESTRAINT SYSTEM visit workshop SRS on my C180 2002 Auto this morning, any suggestions would be most welcome.:D
Does this mean a few hundred pounds at the Merc garage again?:cry:
nickcc101
Helston Cornwall
Read on forum that this could be a fault with the N/S seat sensor, do a search and i'm sure you will find the correct answer as seems to be a common fault. I had the SRS light come on after a battery change seems the power surge tripped the sensor. Had it reset by indi using Star for £35.
As Nick above, normally passenger seat connector, but can onl be checked on STAR, Find an Indy
Cole@MBS
www.mbssouthampton.co.uk
The most common on the 203 is the harness going to the steering control module, needs cutting out and modified wiring harness soildering in!!
T
The Rillo Boy
Thanks for that Guys, the problem I have is that I noticed that the cigarette lighter wasn't working, so my first port of call was to check ALL the fuses on the box at the driverside. After I checked ALL of them ( take them out and put them back in ) is when this problem occured. Good news tho, the cigarette lighter now works !:D
This could have happened if you turned on the ignition with SRS fuse out, if this is the case it just needs clearing on STAR, and indie can do it
T
The Rillo Boy
Cool..... sounds like I don't need to get a loan on Monday then !!!:mrgreen:
