Can anybody help!! My clk 200k suddenly revs to 1500 revs when in neutral then when u put it in gear it goes back down to about 100. Anybody know wha the fault may be?
Ps it's a six speed manual
I am now thinking that you may have motronic, and the reason fo the intermittent could well be the idle change over switch that is built into the throttle body.
If you look at the throttle body there is a plug on the side,,pull this out and see if it just stays at 1500 rpm ,if it is the same with the plug in or out,,then the switch inside will have worn and the car is staying running off the main ECU, and not the idle part.
The top of the air flow sensor can be taken off and the end stops filed away so that the switch can close
Hi just an update went to start it this morning when in idle it's does rev to 1500 then when u put your foot on brake the rev goes down to 1000 revs. Any help or info appreciated?
They hold onto the gears Pete but this one is affected by the brake pedal, and this has to br that pipe with the one way valve in it.. max vacuum is at idle ,,take that pipe off or hole it and the idle RPM will shoot up
d:class automotive are specialists in automotive interiors and upholstery. From Mercedes and modern cars to custom and classics. Tel: 01483 722923
Email:info@dclass.co.ukWeb:www.dclass.co.uk
