cant help with the problem and I'm unsure about the ECU systems used here, but I've found an Australian YouTube channel called 'Mighty Car Mods' and they often have cars with engines fitted 1000km from home and started on a base map, driven home and then put onto a dyno for tuning. the ECUs they use seem to 'learn' the engine parameters during driving and often end up with very little extra to be gained on the dyno. ive no idea if the ECU you are using will 'self learn' in a similar manner.
Stop looking for the Best Garage!! We are here
and have the best advanced solutions for you,
at Competitive prices.
Put us to test with any issue you may have.
