Roof leak fixer - sliding compound roof sealer oil
mdj8
Bucks
SL350 R230 2010
Hello All, after buying a 2010 SL350, it rained on the way home and my passenger daughter complained water dripped on her from the top of the A-pillar. I wasn't too far from home and was concerned and rather unimpressed at this initial problem. Checking online that a special MB silicon lube may fix the problem, it cost nearly £40- for 30ml. Between showers I found some silicon grease and partially opened the roof, dried the rubber on both sides and smeared a thin film of grease on them. This appeared to fix the problem until I drove the car and water again made ingress in the same place. I researched the MB product and determined I should be able to find an alternative at a lesser cost perhaps without the fancy additives. On e-bay I found some pure silicone oil advertised to use on fishing reels. This was only £4.99 for 30 ml and stated it was pure silicone oil. I've since applied and rubbed this oil into every bit of rubber I can find on the roof and had absolutely no leaks during very heavy rainstorms whether driving or not.
Larkone
NW Essex
C219 CLS 320CDI 2008
Discussed further here
brandwooddixon
Wolverhampton
S63 Coupe 2014
Check the sunroof drains, perhaps the one on that corner is blocked. All sunroofs leak to a small extent.
SL63 Mark
Wilts
R231 SL63 AMG
People do recommend Krytox, I am about to buy a bottle and will feed back.
