rotten 210 front subframe
hmang
what are my chances of getting help from mb to fix my very rotten front subframe on my 2002 210 estate.
any one had experience here
rpe2
Silchester
2021 E220, 2019 GLC250, 1986 300SL, 1997 E220 Cabriolet, 1999 SL320
With full service history, and less than 8 years old, possibly. Don't hold your breath though.
You have owned the car for some time,so it must be worth a go, even if you can only get part help towards it
H
hmang
cop this malc...
there's a 10 year warranty on it.
it seems there are 2 repairs possible
1/ replace the lower plate of the subframe if the upper is ok
2/ replace the whole assy
the car went in yesterday for inspection 1/2 hr to determine which repair needed.
booked in for tomorrow to have whole subframe replaced 5hr job should have car back same day.
needless to say, i'm a happy person
fabulous service from jacksons in poole
Thanks for posting a good result :D:D must remember this one
LYNALL
Kent
Make sure they fit the spacers between the frame and the plastic undertray so the new one doesnt have to sit in a puddle of water.
Lynall
Top Cat
Milton Keynes
(97) W202 C230 Elegance Estate
Good result OP.
When inspecting a car for such rot, how can you actually get to see the subframe itself, or is it that you HAVE to remove the undertray to get a proper look? Is the subframe the part that runs under the back of the engine/gearbox area, as I have also seen some rot on a pressed tray that sits under and slightly rearward of the radiator, I'm guessing this area may not be as serious as it seems more accessible and possibly not load bearing?
Does anyone have any photos of what to look for/where to look, maybe even before and after photos for a vehicle that has been corrected?
We did have some pictures up here a few years back, showing where and how they can rust,,but finding them is the hard bit
Top Cat
Milton Keynes
I know Malcolm, since posting earlier today I did have a long search and although I didn't find pictures for a 210 I did find some for other models which gives me an idea of what to look for and where.
Are these generally repairable, if so in situ? Or is it a case of the whole front end of the car needs pulling apart and a new unit fitting?
If the rust is near any mounting points,,then it is a new one only
Xtractorfan
S class
This is the front subframe and you have to remove the undertray to get a good look at it..
FIBAMAN
TYNESIDE
C180,C180,E300TURBO DIESEL
Shouldve tried Harder
This was the main reason I got rid of mine, could get nowhere, then, when the rust started poppin out all over enough was enough.
Still got three drums of new veg oil in garage, even local takeaway wont take them. Replacement car cannot use it.
Anyone like chips?
