Rough running on V230
marknexus
Hi everyone!
First time posting on the forum as i have just become the proud owner of my first merc!
However(!) I seem to have a problem with the running of the vehicle.
It is a P reg V230, 62k miles auto.
When cold the engine runs like a dream, however when hot, it starts to misfire, runs roughly, lacks power and spits and pops back though the intake. It also seems worse when the car is under load.
I am suspecting (hoping?!) its either a plug or more likely the igniter pack breaking down - but would like some more advice before starting work!
I have a few other issues with the car but they will be posted seperatey under the right topics!
Thanks in advance for any help and advice offered!
M
Hi Mark and welcome,,can I just query when you say V230
BlackC55
South coast
C43
The most likely cause is the throttle flap faulting.
get the codes read first.
M
marknexus
Thanks for your input guys. I changed the plugs and one coil and it seems (touch wood!) to be behaving.
If i have a repeat problem I will get the codes read as suggested.
Thanks again!
M
mps750
New Registration
v230 with a misfire
Hi guys
I have a 97 v230 petrol that has developed a misfire? I have changed coil packs, ht leads, plugs and had the ecu tested, the ecu tested fine but i still have the misfire. It appears to disappear above 4000 revs.
Any one experienced this before, I understand that these have alot of history with the ecu so I was totally shocked to find that it tested fine??:confused:
simon iow
isle of wight
v230/1999/2200
Hi , there can anyone let me know the best way to get at the plugs and coil packs on my v230, do you have to take the inlet manifold off or???
