rough running
lackofgrip
Close enough
just had my car serviced and i was having running problems anyway it wont run without the maf plug disconnected, just wondering if this was a problem anyone else has had. it does drive with it plugged in but very hesitant with flat spots with it unplugged it pulls like a train. was wondering if it could be the lambda sensor that is knackered or maf?? or both???
It does sound more MAF related to me.
lackofgrip
lackofgrip
Close enough
ive got a can of isopropyl alcohol from maplins (not spray).
whats the best way to clean it?
can i just submerge the whole maf?
There are 2 types of sensor, the open wire and encapsulated, they must not be submerged and they do not always respond to cleaning, nothing lost though as it does work sometimes
lackofgrip
lackofgrip
Close enough
i was thinking of using an old window spray bottle to spray it on, can i just leave it to dry itself? or do i need to wipe it?
leave it to dry would be the best if it is the wire, the encapsulated could be carefully wiped
lackofgrip
lackofgrip
Close enough
should it work just cleaning it? as it just runs rough as oppose to not at all.
So sorry I do not have that answer, different models are so individual
lackofgrip
lackofgrip
Close enough
no probs will try cleaning it in the morning, will it damage anything running it without it being plugged in?
Nope, all that happens is that the engine ECU cannot adjust to the air temperature,etc
lackofgrip
lackofgrip
Close enough
so im ok to run it unplugged for time being without any damage at all ?? thats a relief.
rio678
cornwall !
Sounds like a new MAF sensor is in order to me, i would spray it well and leave to dry naturally on a paper towel for a good time and clean the air intake and box while your at it.
lackofgrip
lackofgrip
Close enough
cleaned the maf and airbox still rough on idle with flat spots. could it be the lambda sensor that is cooked as the exhaust that is on is brand new and the on that was on befores cat was wrong.
possible, the LAMBDA does control the emissions and the fuel/air ratio, as in the case of contaminated fuel, the engine runs lean and this could cause flat spots, as can the MAF. As I said before cleaning is no guarantee of a cure.
Short of a diagnosis read out out there is no way of telling short of replacing.
lackofgrip
lackofgrip
Close enough
fuel contamination??? im gonna replace the lambda sensor first as its cheaper than the maf. if that doesnt work will have to change the maf.
rio678
cornwall !
I would really say it's the MAF , as if it runs fine without it plugged in, then it really could be faulty. Sometimes cleaning won't work, it could just be past repair.
lackofgrip
lackofgrip
Close enough
  • #18
how much are they? gsf say £180 thats why i wanted to try it with the lambda sensor first as they are only £40. is there anyone local who i could swap maf's with to try it out?
£58 from bosch agent, or service center.
