Rounded off bolt....what to do next?
Status
Not open for further replies.
mjtray
Reading
Right,
Just went to change the oil on my recently acquired W124 300D and found that the sump pan bolt had the consistency of butter and rounded off...what do I do next :shock:
Somebody has suggested mole grips and once its shifted making sure that the bolt is replaced (obviously).
Is this the best way to get this bolt undone?....the thought of having to pay ££'s to get it tapped out does not fill me with joy.
HELP!!!!
LNM
Birkenhead.
Ayup
Have you tried the Mole grips? Seriously, its the first thing I'd do.
teky
UK North East ish
failing that a nice pipe wrench will do it and when you fit a new bolt dont forget the copper seal
Spike
London
1999 SL500
... and if you get *really* stuck, find an old manky spanner and spot weld it onto the rounded off bolt :)
TimN
Hertfordshire
Bang on a size smaller socket. Don't use a six sided socket but one of the cheaper types that hold the bolt on the apex rather than the side. Use an imperial if that cuts nicely into the bolt head. I also find the star bolt sockets (For want of a better discription), the type used on some cylinder head bolts pretty good for this application.
In the past I have welded another clean nut onto a head of a bolt by spotting through the centre of the nut.
Why not just remove the dip stick. Get yourself a hand pump and stick the suction pipe down the dip stick hole and forget about removing the bolt, jacking up the car and getting generally unnecessarily uncomfortable and dirty and get the job done much quicker without spilling oil etc.
mjtray
Reading
By sucking up the oil out of the dip stick tube, don't you run the risk of leaving a load of crud at the bottom of the sump, or have I been reading too many horror stories?
190
Banned
Scotland
I agree with Tim N hammer a smaller socket onto the sump plug
P
pluggers
Might be a bit dodgy hitting a small socket over the nut as it could cause the sump to crack :shock:
Id be tempted to use grips/stilsons or some kind of self tightning spanner for the job.
landover
Banned
Scotland
www.landrovertd.com
Dont use a hammer on your sump or vice grips .You can take it off with a TURBO socket .These sockets grip as you turn .Same idea as an easy out Snap on tools do them . Even borrow one from local garage.
Myros
R107, S211, R170, C219
tough nut
MJTray, time for me to return a favour. You could get a chisel and gently hammer it in the nut anti-clockwise and try and turn it that way as well. You can do this 3 or 4 times before you need a new nut, but I recommend it as emergency kind of thing. I'd be dead careful though, as it's a vital bit of the car to be hacking about with. You could also file new flats on the nut and try the mole grip/socket routine. Give it a good dose of wd40 or penetrating oil before you get to grips with it.
The C280 still starts like a dream, but I had bit of a do with oil level last week.
Good luck, Myros
Status
