91 300CE 24V on 53k
Just returned from a round trip to N.Yorkshire via Manchester and South Cheshire - car ran without a hitch except..
I notice the temp is around 80 under normal driving but will slowly climb to 110 in traffic (AC was off) - today's external temp in London was showing 19-20 so I'm thinking a little preventitive maintenance is in order before the summer kicks in. It doesn't appear to be losing coolant and the car has curiously only one electric fan at the front...
From reading other posts I have not heard the aux fan kick in... so I'm assuming the following course of action:
1. Run the car to temp and try the 'carrot' test on viscous fan.
2. Change coolant and replace with decent stuff and correct mix.
3. Change thermostat subject to results of 1 & 2.
4. Change viscous fan coupling subject to results of 1.
5. Change water pump if all the above fail..
Any other thoughts on this - I've got a digital volt meter somewhere which I can prod at various electrical bits with guidance...
Ade :???:
Ade :???:
