I have a 1999 C220CDI, which has some small patches of rust on it, i was wondering if it was covered by the Mercedes Rust Guarantee? It does have a full service history
If not does anyone know when it came in?
Thanks Tim
Lets face it, get a chunk of average car bodywork, remove all the paint and leave it in your garden for 6 years.
I am happy to be able to tell you that that is not true of the Mercedes policy. Numerous threads give testimony to the fact that the policy does exactly what it says on the tin.
Mercedes have dealt with many rust cases on cars with full MBSH and they have also dealt with quite a few with partial MBSH. I can give you loads of links or you can search here, on other UK forums and in the US.
RUST and MOBILO
30 year guarantee began with Mobilo on 24th October 1998
Full galvanising of all steel panels on Mercedes began around 2002 and most models were fully galvanised by 2003. I'll post the link in a second or two.
Useful thread on rust and Mercedes fixing the problem for some but not all: -
http://forums.mercedesclub.org.uk/showthread.php?t=30656&highlight=rust
A case where Mercedes did lots under ‘goodwill’
http://forums.mercedesclub.org.uk/showthread.php?t=30644&highlight=rust
Another useful thread with lots of information and many cases of Mercedes paying for rust to be treated: -
http://forums.mercedesclub.org.uk/showthread.php?t=27552&highlight=rust
Another interesting thread giving info on the eight years cover prior to MobiloLife coming in.
http://forums.mercedesclub.org.uk/showthread.php?t=29655&highlight=rust
In that case, apologies are in order. Maybe I should be slightly less sceptical.
Normally your scepticism is spot on, I'm sure. But in this rare case it does what they say.
BUT: - modern water based paints are not truly waterproof and it is the clear lacquer that provides the real protection. Once that is broken by stone chips or scratches or minor accident damage, if it is not touched up properly, then rust can easily occur from the outside in -which is not covered.
Repairs which have been done by a non approved bodyshop are not covered.
So provided all repairs are done by an approved bodyshop, and provided reasonable care is taken to touch up damaged areas then you are covered for rust from the inside out as it says in the T's and C's - given full MBSH.
Thank you very much, and it was nice meeting you on Sunday!!
