philharve
- Jan 20, 2005
- Age
- 73
- Location
- Falmouth, Cornwall, United Kingdom
- Website
- go.to
- W202 C230K Auto 2000
Hi All
I was refilling my windscreen washer reservoir when my eye was caught by a small patch of flakey rust that was appearing around one of the drain/vent holes in the underskin of the bonnet. Though not serious, I decided the spray Waxoyl around and inside the hole, between the inner and outer skins of the bonnet. No doubt that will inhibit the spread of the corrosion.
Then I got to thinking that finding rust in the engine compartment area is unusual (IMO) because the hot, oily environment tends to drive out moisture and coat the exposed, painted metal surfaces with a fine, greasy layer that helps keeps moisture at bay and inhibits the corrosion process. Finding rust on the bonnet's inner skin therefore came as a bit of a surprise to me. I wonder how common it is in Mercedes vehicles? I have seen it in other makes, particularly where it spreads and eventually eats through the bonnet's outer skin and creates unsightly rust bubbles under the paintwork.
I like Waxoyl because it's widely available and it's relatively inexpensive. But I have used Dinitrol's range of products on my previous car with great success and I thought I would like to use them again on the Merc'. I have purchased a couple of Dinitrol's spray products from Frost Restoration along with several 60cm spray hoses that should enable me to reach into every cavity of the bonnet. On the next fine day I will give my bonnet's cavities a good rustproofing treat.
But I am still wondering why rust should break out in the underskin of the bonnet? Could a small leak in a windscreen washer hose initiate the corrosion process because where the rust has formed, around a hole near the leading edge of the bonnet, is not a water trap area. Has any other member experienced corrosion in or around the engine department including the underside of the bonnet?
REGARDS
Phil
REGARDS
Phil
