Aussie Nick
I am commencing this thread in respect to the several rust issues that have occurred with Mercs on this forum.This one is in relation to some easy maintenance on the rear boot seal and gutter area of a W202.
The first attachment shows the rear boot seal with the boot open of course.
Grab the seal from around the centre of the boot and lift it clear of the boot gutter rail.
In the second attachment it can be observed that the boot seal rubber has been lifted clear of the rail. It should unclip relatively easy. Ensure to unclip the rubber around the curved corners of the boot . It is not necessary to unclip it any further than just south of the boot corners.
Inspect the boot gutter. I expect that an inspection will reveal a build up of grime, dirt and debris.The one I depicted in the third attachment was cleaned three months ago yet still shows build up of dirt, which left unattended will attract moisture and start to affect the paint and subsequently the steel. If you add traces of salt to this concoction, the roof gutter and surrounding areas are destinied for a quick rusty finish.
Normal car shampoo with a rag should be used to wipe away the grime. It is recommended that the area be allowed to dry totally before the boot rubber seal is reclipped back into place. I would be grateful if anyone who tries the maintenace comes back on the forum to provide feedback as to what their particular inspection revealed and whether they considered this thread worthwhile.
Regards Aussie Nick.
