S 350 TD 1994 problem !
Y
Yvete
Help/info needed.
1.Hazard warning light not working.
Hazard switch replaced.Indicator switch replaced.Multifunction relay
(indicators,wipers,rear window heating) replaced.All O.K. after new parts
for short while and now back to original problem.Any ideas ?
2.On removal off rear door cards (trim panels).
I have undone plastic studs around the edge.Is there hidden screws or
bolts ? If so what is the method of removal ?
Any info will be appreciated.
Y
Yvete
Thanks for answer.Any idea what caused that ?
Poor connections in the relay socket can also cause your problem, try putting some pressure on it or pushing it to one side with the indicators set to flashing
I do not think that the relay would go again
Y
Yvete
Thanks.But still not working.
