S Class Clock
ROBERTG
The clock (radio controlled) is still showing BST, one hour ahead. I tried disconnecting the battery and reconnected it at exactly 12.00 hours, switched off the RDS, and it still jumped an hour ahead - any clues?
Hello and welcome, do you have the comand in your car
R
ROBERTG
Hi Malcolm, yes it has command. The book says the clock is adjusted automatically by the RDS.
Go into the set time and date in the Comand menu, you will find it under SYS Date Time, there you can change the time and switch to automatic Summer Winter time, and more
R
ROBERTG
Hi again Malcolm, thanks for reply but as I said earlier, and I quote from the book "If a navigation system is installed on your vehicle, the clock is radio-controlled". I have a sat nav within the comand, and in the relevant submenu under SETTINGS there is no clock function.
You still have a menu where you can adjust the time and date, and also turn summer time off and on, all Comands do
R
ROBERTG
Thank you Malcolm for your help, the country setting was Germany (???). My first time in the Systems menu!
Regards
ROBERTG
