S Class W140 bulb warning light on dash stays on
380560
Isle of Skye Highlands
S Class, W140 4.2 Limo, Nissan 300ZX twin turbo, Porsche 911.
Hi I have just replaced the front side light bulbs (501 bulbs) and now the dash board "bulb out" warning light stays on. I have checked all the bulbs and all appear to be OK. Is there somrthing I need to do to re set the warning light?
JEZ.S320L
Costa Calida, Spain
www.latorreonline.es
Hello,
Have you checked the rear lights and brake lights as well?
As far as I know, there is nothing to reset.
380560
checked all bulbs.......i am assuning there is just one rear fog light?
Wirral_guy
Ness, nr Chester
2004 CLK270cdi Avantgarde
Have you tried putting the original bulbs back in? It might not like the new bulbs, especially if you're trying to fit led ones or some of the blue bulbs as they don't always get to 5 watts which the car perceives as a blown bulb.
Dave
380560
...............good idea, i will try it as soon as it stops rain up here on isle of skye...............oh by the way this is a good place to come for a Spring/ Summer club drive out for a day or so..................nice B&Bs and hotels........your thoughts anybody?
ps it doesn't alway rain up here........honest!
999choc
got a similar problem with my e200.the yellow warning bulb light remains on. but sometimes goes off again. i have noticed that my reverse lights work one minute then not hte nex. any ideas .thanks
Often as the cars age a wire can break in the hinge area, and that is more common than a faulty switch
mikestrivens
Stockport
I have had this problem before. It turned out to be a lamp (bulbs grow in the garden) where the cement holding the glass had come away from the metal holder and was causing intermitant failure. Took a while to find the right one but take every lamp out and check that the glass bit is securely held into the metal mount.
