S Class (W221) Throttle response
BRP
From rest and when in motion there is a small delay (approx. 2 secs. max.) between pressing the pedal and a response happening. The same sort of feeling you would get if insufficient revs applied on a manual car. Not a big problem and is most noticible when wanting to quickly slip out at a roundabout.
The dealer says "not excessive and they are all like it". I have used automatics for many years. I thought that this function may be adjustable. Any help appreciated.
BRP
I just rang my friend with the same car and he says that his throtle is instant
This could be very dangerous in some situations.
Malcolm
B
BRP
Thank you for the quick reply Malcolm. When my wife and one of my sons drive the car they do not notice the delay, Although I am sure the son (nutter in car) will notice eventually! When setting off you have to sort of 'feed' the power as if to prevent a stall. Because the car is relatively powerfull to most people I think they are wary of pressing the pedal too hard. Like everything on this car I presume it would be an electrical fault.
Thank you for taking the trouble to contact your friend.
