danielsm4a11
- Dec 3, 2022
- mercedes c270cdi (2004) s203
hey guys im searching for help!
Soo my problem started with bad start, rebuild the fuel pump, new orings, new pipes, ( gas tank doesnt have a fuel pump)
the fuel supply now is perfect no bubble!
new glow plugs new glow plug relay, pre heating working, engine rebuilt good compression.
but the problem now is its going good for 4days, the engine starts half egine revelution, the generator charging 14.7v( also new battery Deta senator 100A)
The problem is its showing undervoltage but the battery is 12.8v, the ecu doesnt open the injectors, you can crank the engine for 4h it wont start.
i suspect the ecu doesnt get enough voltage or whats the problem i dont understant, the car is getting on my nervs, then i put aa new negative cable its started then after a week i cant start the piece of **#%, so i really searching for someone who can tell where to look for the problem
