S204.208 2008 C220Cdi Horns
Chrishazle
Nr Ashford, Kent
The horn on my car has gone anaemic, single tone and quiet. I've tried 2 parts sites trying to get the part numbers in order to buy replacements, but searching by type (204.208) and by VIN (missing from database!) I get a list of 4 or more different part numbers for each of the 2 horns (horn and fanfare horn) for my vehicle. VIN is WDD2042082F200232. Can anyone help determine which of the many part numbers is correct for my car - would be much appreciated.
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
All the Part#'s will fit.
Mercedes bring out superseded Part#s but each one will be suitable.
These will fit
Chrishazle
Chrishazle
Nr Ashford, Kent
An update : Looking on Youtube I found 2 "How To" videos, 1 showing that you could access the OS horn by removing the front OS wheel and pulling the wheel arch liner back, the other showing that you needed to remove the front bumper - which you certainly do to access the NS horn. So I bought 2 NOS genuine MB horns (400Hz low tone NS, 500Hz high tone OS), took them and the car to a decent garage (not MB!), who found that you can indeed access and remove the OS horn via the wheel arch.
However, the old horn had spade connectors, the replacements have moulded on plugs, so it would appear that not all part numbers are a direct replacement! The garage has been able to source a Bosch replacement with the correct connectors but will have to use the bracket from the old horn to attach it. Supply and fit is (probably +VAT) £98, which I'm quite pleased with.
I'll update this again with the part numbers of the NOS horns and, if I can, the part number of the old removed one.
