S205 not stop starting do I need a trickle charger?
ioweddie
Winford Isle of Wight
W205 AMG Sport Line Premier Plus Estate C220d
Hi All.
My c220d s205 2015. The stop start has not actuated for ages, I have not done any long trips and wondered if the battery might not be fully charged, air con always on, I wondered if an over night trickle charge might make a difference. If so any recommendations on which one to buy.
Thanks Eddie
Wabby
MY17 C250d Coupè
Just do a 60 mile drive mate. Works for me
If you're going to buy a charger the CTEK Stop Start specific one is the best.
bembo449
gainsborough , lincolnshire
stop/ start wont worl if the car thinks the battery isn't upto the job so like your already thinking , the battery probably needs a charge OR you need to drive further , my old astra VXR only ever did 5 stop/ starts in 2 1/2 years of ownership due to lack of use
ioweddie
ioweddie
Anyone know if charging the main battery also charges the auxiliary one as well, sorry for the dumb question but I'm not really up to speed on electrics.
Thanks Eddie
Not wholly familiar with your model Eddie but my similarly aged car has a convenience battery in the boot which is for the stop start function. If you have the same then that’s the one to trickle. I don’t believe they are linked ..
ioweddie
ioweddie
Well I bought a CTEK MSX 5.0 for £67.95 delivered from these guys:
https://www.smarterchargers.co.uk/
Brilliant service, excellent communicators and very knowledgeable.
The car is now on charge, I'll let you know if the stop starts working again.
ioweddie
ioweddie
Brilliant a result. It works, after an overnight charge the stop start is active again. So the battery was 80% charged which is fine to start and keep the car running fine, but it needs to be at optimum charge to satisfy the requirements of stop / start. So it appears it will need a boost due to short journeys every couple of weeks.
If you are experiencing the same problems this charger is definitely the way to go.
Thanks for all the responses everyone.
Stay Safe! Be Lucky
Eddie
