S210 not crank, even replacing battery...
bob 6600
Audi S8 V10, S210 E320 CDI (R.I.P.)
Is your a E320 cdi avantgard estate?!
I don’t k ow why your have a 10Amp fuse :/
Yep 2000 S210 E320 CDI AG
ajlsl600
france
i have had a good number of incidents where the starter stops in one place and is then lazy or wont turn on restart attempt sometimes a partial turn has it working again ,if so only fix is replacement . but for sure every reason to interview starter and learn something,if its not exchange unit.
Linuus
Linuus
crawley
w210 wagon
  • #44
Will need to investigate why mine is 15A... :/ I can’t find any schematics for that k40
om613
london
S202 C250TD, S123 240TD
I had that non-start thing once ... not since the battery was changed.
Linuus
Linuus
crawley
w210 wagon
  • #46
in my case I had a jump start, didn't work, so I bought a new battery didn't work, so with help the forum I looked close into the k40 module relay and circuit board and the track was burnt. so I've done a "bridge" to connect from pin point A to pin point B with a small wire and from that moment I could hear the relay clicking, and then, me and my friend moved forward to the starter and we saw current on the starter but the motor doesn't want to work so, I am waiting for a new starter to be then install as well the k40 module everything should arrive by Tuesday. and hopefully the issue will be sorted... other wise, I will need to take him into a MB specialist...
Linuus
Linuus
crawley
w210 wagon
  • #48
So I’ve order secund hand k40 relay but it’s diferente from the one in my car I just have notice that my one has 2 holes close to the part number and a number 053761(20) and the one I’ve order has a number 053761(00) so I guess better not to try not to mess around with the electric... here the picture from mine inside the car and the one I bought..
What do I do now?!
bob 6600
You should really get one with the same part number. It's stamped on the part
Linuus
Linuus
crawley
w210 wagon
  • #50
Just bought the correct one now!!! Need to be this one, because MB wants 87£ for it... -.-“
Linuus
Linuus
crawley
w210 wagon
  • #51
[SOLVED] So, just to close this thread, I can confirm the starter was bad, replaced, with a new one, old k40 still working with the bridge I’ve done. But I have a new one to install next day off. Just done one thing, be careful with disconnecting battery. Now need to enter radio code and reset all windows, that what I have notice so far from disconnecting the battery right guys? Or is there any gremlins I shall be aware of... thanks
bob 6600
You will have got BAS ABS errors too, just turn steering from lock to lock and they will disappear
Linuus
Linuus
crawley
w210 wagon
  • #55
Nice @bob6600 will to that. Yesterday done all windows and sunroof “tuning” and radio was skipping from CDC to radio and vice versa, don’t know if that anything to do with the battery disconnection
ajlsl600
france
yr the go to man for all the gen ref that issue for a while .....!! would say starter had something to do wid yr fried board.tho would also have thought fuse there to prevent that...
