sverker
Registered
- Jun 26, 2023
- S211 2008 320 CDI
I have a S211 with self leveling suspension, i.e. air springs in the rear. Over the past years I've been having reoccuring issues, it started fall 2021 with the right spring blowing with a loud bang. I was able to make it to my parents house but it was a bumpy ride. I got a pair of replacement springs and a local workshop (my cousin's) were going to replace them. Due to time constraint he could only change the right one so I was going to come back another day so they could change the left but since that's 200 km from where I live and the system was working as it should I never got time for it. However since that episode I got a warning message of a disturbance on the air suspension and a fault code on the left spring.
Fast forward to late summer 2022, then again when on my way to my parents place the right spring lost air just a few km before arriving. This time I took it to a workshop specialized on MB with a good reputation, they made a thorough effort on troubleshooting but could not find the root cause on why it displayed the warning message and set a fault code. They changed both air spring (the right was broken which was the reason why it lost air), the control module and measured the wiring between the module and the springs. Still the warning message and fault code was there. Since the suspension worked anyway I didn't want to spend more money on troubleshooting then, and I needed the car.
Fast forward again to last week when it lost air on both sides, forturnatly just a few km from my home but it was a bumpy ride to get back. This time I spent some time on troubleshooting myself and concluded that the compressor while running didn't pump any air. There are rebuild kit for it, but that would have to be ordered from UK and I found a local company 20 min away that had a new compressor in stock which I could pick up today. Replaced the compressor and wanted to test it before I put back the wheel well and wheel so the car was still jacked up on left front.
Started the car, the new compressor pumped up left rear but right rear was low although with left front jacked up it would press down the rear right. Since the compressor obviously was working fine I put back the well and the weel. The right rear was still low, it raised and lowered like it was trying to adjust. Took it for a test drive and it behaved normal, ie. no bumpy ride at all. However, right rear is still lower than left rear.
My question is, since there to my understanding is only one height sensor how does the control unit know that the car is level? If it's high on left and low on right the sensor would still report the correct average height. As I understand the procedure with Star is to command both air springs to bleed and then pump them up on a level surface so that they'll be even. I tried to jack it up on right rear but that didn't fool the system, it still lowered the right side. Of course it's possible that it was the right spring that broke again and with the extra strain the compressor died. After all, this car has 470 000 km (close to 300 000 miles) and I think it was the original compressor so it is understandable.
The warning message I've had on suspension went away when compressor was replaced, so it seems the control unit is satisfied even though the car is not level. Is it necessary to connect Star to align it or will it self align? Unforturnatly I just have an iCarSoft unit which doesn't have the function to bleed the air springs.
