S212 E350 Stop start not working
costacor
S212 E350 CDI
Hi all. Longtime lurker first time poster
So my 2012 S212 E350 which has always been serviced by MB under the service plan but is not doing the stop/start thing anymore.
I used the secret menu to check out battery condition and it states 12V engine off and 14.5V when engine on
Battery never been changed, so would I be correct in thinking it’s the battery that’s probably causing the issue? How do you find out the status of the aux battery? Shall I just change the battery? No visual indications anything is amiss
Other than that, never had an issue with the car in all the years I have had, save for rear air suspension. Lovely motor
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Charge the main until it says 12.7 v or near enough. Usually 24 hours on a smart charger . See if things improve. Also maybe charge the small aux ,check dates ,maybe time for both ?
C
costacor
S212 E350 CDI
Thanks dude. Neither battery being changed in my ownership and that’s 8 years now . I’m surprised they have lasted this long . Would it be just better to change both? Is the aux battery change a simple Kwik fit job?
malcolm E53 AMG
If the main battery is the original you are doing well I changed mine a couple of years ago.
I’m in the process of ordering a new auxiliary battery before it causes problems
onefortheroad
uk.
I'd imagine so. I changed mine myself .
Gazwould
C250 CDI
Stop Strain not working is cause for celebration 12_16_19-e1648167595512.jpg
My 2011 battery has very similar readings and is starting the engine no problem and that was 1.5 years ago .
tpn
S204 OM651 2012, Daimler V8 250 X 3
My stop start stopped working some time ago and it was a failing main battery. 11.85 at the battery. You need to check at the battery as other components will be taking some power.
I never use the stop start, but I do like to know why it is not working.
Unfortunately my main battery dropped to the stage where it failed to turn the engine and took out the A/C Module:mad:
ajlsl600
france
And where was the protection to avoid that happening.
My understanding, stop start u avail during regen?
