frubpato
- Jul 5, 2013
- Location
- Northwich
- S212 2010 250 cdi estate
This ****** car is messing with me - sometimes it will keep its ass in the air for 2weeks plus - even when left in an airport car park , and at other times over night or even within a couple of hours it is right down on its hunkers.
i guess that would suggest its not a airbag leak or even the pipes as that would be constant , could it be a battery issue where the electronic level sensors to the distribution block require a certain voltage to keep things level?
any other ideas - btw the codes for "level sensor" signal outside permitted range is generated when the car goes down but otherwise everything is fine - the right left heights are 4 mm out but that could easily be due to me being in the car when the codes are being read
