S320 CDI Battery Drains
sajmeister
New Registration
I have a S320 CDI Mercedes and the battery drains completly after 48 hours.
Any ideas what could be causing this ?
I have had 2 new batteries installed and they all have drained after 48 hours.
Thanks.
Hello and welcome to the forum, the only way that this can be solved is by having an ammeter in series and pulling the fuses one by one
MIW615
Leafy Surrey
C200 SPORT & 230SLK
Thanks.
When measuring the "drain" I would expect it to be around 50 - 60 ma, any more than that then do as Malcolm says untill you trace the offending circuit ;)
BlackC55
South coast
C43
You will find it very difficult to find.
Just pulling fuses does not always find the problem as some control units can cause a drain and they are not always fused. (40+ control units on some s classes)
There is a certain proceedure that it labour intensive for this kind of car.
Firstly remove the sat nav disc at they are prone to cause a current drain (stay on when car is switched off)
Look for any illumination still on inside the car when locked for 40 mins indicating a drain. (instrument cluster is a faverourite)
Make sure the battery is good.
BlackC55
South coast
C43
0.06A-0.07A is absolute maximum drain.
It must be checked when the car is locked and asleep (30-40mins)
hmang
don't forget the alternator ...it could drain back through there
check with ammeter in line
Tel: 020 8863 9233
